SNMP monitoring SSID radio interfaces
I’m trying to monitor the our Aruba 115 IAPs and SNMP walking the ifTable it shows several different interfaces:
IF-MIB::ifDescr.1 = STRING: eth0
IF-MIB::ifDescr.50 = STRING: radio0_ssid_id0
IF-MIB::ifDescr.52 = STRING: radio0_ssid_id2
IF-MIB::ifDescr.54 = STRING: radio0_ssid_id4
IF-MIB::ifDescr.72 = STRING: radio1_ssid_id2
IF-MIB::ifDescr.73 = STRING: radio1_ssid_id3
IF-MIB::ifDescr.74 = STRING: radio1_ssid_id4
IF-MIB::ifDescr.75 = STRING: radio1_ssid_id5
I get interface counters for all of the above interfaces, so all is well.
What I’m trying to do is to find out what SSID those radio ID’s map to.
For example, if we have 4 SSID’s (WIFI1/2/3/4), how do I know if radio0_ssid_id0 = WIFI1 SSID ?
Also, why does it display ssid_id2  and ssid_id4 twice (different radio0/1), but not the rest?
Using the Aruba MIBs its fairly easy to pinpoint the broadcasted SSIDs, but if I can monitor counters on the radio interfaces PER SSID and PER access point, that could be very handy for graphing and monitoring. Unfortunately, they don’t seem to line up:
AI-AP-MIB::aiSSID.0 = STRING: WIFI1
AI-AP-MIB::aiSSID.1 = STRING: WIFI2
AI-AP-MIB::aiSSID.2 = STRING: WIFI3
AI-AP-MIB::aiSSID.3 = STRING: WIFI4
I would have hoped to have seen .52 = WIFI1    .52 = WIFI2, etc etc
Any help would be appreciated.
Phill.
