Guest Blogger
Serial Number of Airwave Running as a Virtual Machine
From either the command line or web interface, how do I obtian the serial number of an Airwave Server that runs as either a virtual machine? What about an Airwave server that runs as a physical device? I have run AMP 7.7.5, 7.7.10, and 8.0 Beta_F.
MVP
Re: Serial Number of Airwave Running as a Virtual Machine
From the Web-GUI, click on 'Home' and then 'License'
The license page should show the serial number or your license.
The machines are licensed by IP address.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
