Contributor II
Setting bandwidth limit on guest users
I want to setup bandwidth limits on the guest WLAN per user, but all I can find are bandwidth limits on applications/web pages and create bandwidth white lists... I tried following this guide, but none of the options exist..
http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/Firewall_Roles/User_Roles.htm
I am trying to do so on an Aruba 7005 controller running 6.4.3. Does anyone know where I can set this.
Kind regards,
Tom
Re: Setting bandwidth limit on guest users
Do you have PEF licenses installed?
Tim Cappalli | Aruba Security
Contributor II
Not yet. Do you need PEF licenses for that? I will get that sorted then..
I presume I'll need PEF licenses to limit the connection time too or is that something else?
You need PEF for limiting bandwidth.  You can send a radius COA from a radius server to disconnect a user without a bandwidth limit.
