Setting up Dynamic Radius Proxy when IAP:s are offline with unique IP-adresses?
Hello Airheads,
I would like to know if it's possible to setup Dynamic Radius Proxy with unique Dynamic Radius Proxy IP-adresses, vlans, subnets and route when the IAP is offline?
We also would like to pre populate all the names for the VC:s and IP-adresses of the VC:s?
For instance can i first create the VC and then add the accesspoints to the VC when they come online?
Regards
Rickard
Re: Setting up Dynamic Radius Proxy when IAP:s are offline with unique IP-adresses?
Is this AirWave or Aruba Central?
Tim Cappalli | Aruba Security
We are using the Airwave platform.
