Occasional Contributor I
Setting up IAP215 to have two SSIDs one for 2.4 and the other 5.0
I have a a IAP215 and I would like to configure it so it does the following.
1. SSID which will run on 2.4G
2. SSID which will run on 5G
How can I do this?
Re: Setting up IAP215 to have two SSIDs one for 2.4 and the other 5.0
Band in the SSID profile?  http://www.arubanetworks.com/techdocs/Instant_42_WebHelp/InstantWebHelp.htm?_ga=1.43038629.1615771646.1440445030#UG_files/WLAN_SSID_conf/ConfiguringWLANPro.htm?Highlight=band
Thanks for the quick reply.. I can't believe I didn't see that.
