Signal Slow and High Utilization
We have an issue where our Client are in Low Signal Strange and using Very high Utilization.
Each AP properly place far from each other.
Re: Signal Slow and High Utilization
What is the min and max transmit power for 2.4ghz under the ARM settings?  You probably have to lower the max for your 2.4ghz band.
Hi Colin,
I have attach two screen show
1. Current Default,
So base on your recommendatino i need to tick cusotmize and if so which number should i put for Max?
Change the min and max to 12,
