ed
Contributor I
Spectrum Monitoring
Recently updated to the new 4.0 firmware and I must say that I really do appreciate the client-match functionality.   One thing that I have noticed is that the "spectrum" tab does not display.  I turn on "background sprectrum monitoring" and then select an appropriate AP but there is no "specturm" tab to select.  Perhaps I am missing something.  Thoughts?
Re: Spectrum Monitoring
What is the model of the IAP that you are trying to get a spectrum report on?
ed
Contributor I
I am using IAP-105.  I have enabled backgroup spectrum monitoring, but I never see the "spectrum" tab that usually shows up next the the "Monitoring" tab.
Moderator
Have you clicked on / highlighted the AP first?   Here is my IAP-135 with v.4.0.spectrum.jpg
ed
Contributor I
Yes, I click the appropiate AP but the "Spectrum" button does not appear on the IAP-105....or at least on mine.  I also tried rebooting all the APs just to make sure I didn't need to have this done first after making the setting.  It used to work on the prior version of firmware, but seems to be causing me issues once I have uprgraded.
Just chiming in and I have iap-105 us version on firmware 6.3.1.1-4.0.0.1_41049 and I can't find that  spectrum button either.  Thanks.....
IAP-105's hybrid Spectrum mode had been removed from 4.0 release.
ed
Contributor I
So if  this (specturm monitoring) has been removed on the IAP-105, am I to assume that the "background spectrum monitoring" option will have no effect if I enable it?
You can use the standalone mode spectrum in per AP setting.
Frequent Contributor II
I have upgraded to 6.3.1.2-4.0.0.2_41506 and still no Spectrum tab even with the option in the RF enabled for background scanning.
If you found my post helpful, please give kudos!
