Occasional Contributor I
Ssid guest configured on aruba 650 not erasable or editable by wizard
Hi there,
In controller 650 i have 2 ssid (corporate , guest).
when i try to modify ssid  guest by wizard, system say me "impossible change parameter from wizard".
The name "guest"  in ssid's table is in light gray  while "corporate" is typed in black.
How can i do to erase this ssid by GUI or by consolle?
Thanx in advance.
Re: Ssid guest configured on aruba 650 not erasable or editable by wizard
Navigate to the AP group you created, under virtual AP -> SSID profile, you can change it there.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Hi Pasquale,
how did it happen?
Thanx again
How did what happen?
I assume through the wizard it will not let you modify it, hence you must manually adjust it within the profile
ACDX #420 | ACCA
