Strange model 105 series
Which model do i have?
I have 6 model 105 ap's or iap's. Who can help? They have no extra label stating the right model AP-105 or IAP-105. They have a reset button. So I think that they must be IAP. But they seem to be loaded with AOS firmware.
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
Re: Strange model 105 series
All APs have a reset button.  You would only know what an AP is by emailing tac with the serial number.
Colin Joseph
Aruba Customer Engineering
My other AP--105 have no reset button.
Cheers, Frank
Let me check.  When the AP105s first were made, they did not have reset buttons.  When IAP-105s started being made, I think reset buttons were added to all APs after that..
I think...
Colin Joseph
So the answer is yes.  After we released the IAP-105, we starting also producing AP-105s with reset buttons.  You might have to ask TAC which serial numbers you have started life as an IAP vs. a CAP 105.
Colin Joseph
Thx Colin. I will check with TAC if they are ap or iap.
Cheers, Frank
Good to known :-)
ACMP 6.4 / ACMX #107 / ACCP 6.5
