Occasional Contributor I
Syslog of 4 IAP (virtual controller)
Hello guys.
I have recently installed 4 x Aruba 205 IAP's, and we have to log about the data, users how connected and so on.
Is it possible to monitor/syslog, which user/IP/MAC uses traffic from facebook.com and so on?
Best regards
Re: Syslog of 4 IAP (virtual controller)
You could do this with Airwave but this kind of thing is often handled by a firewall.
I don't believe the IAP syslogging will provide details of clients browsing to facebook.
Cheers
James
Cheers
James
MVP
I've had some luck getting traffic data (IP to IP and port) by turining on logging for the allow-rules on the security roles associated to SSIDs, but you won't get URL or DNS request data, just the connection.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
