Syslog problem
  • 1.  Syslog problem
    Posted May 01, 2013 09:54 AM
    I am trying to configure my IAP 105 to send syslog to my syslog server. It works with the ClearPass server to Syslog server but the IAP doesn't send any syslog information. Syslog level is Information. What am I doing wrong ?
    Any idea ?
    Regards
    Dimitri
  • 2.  RE: Syslog problem
    Posted May 01, 2013 09:57 AM
    Can you please share a screenshot of how you have it setup ?
  • 3.  RE: Syslog problem
    Posted May 01, 2013 10:03 AM
    Here it is :
  • 4.  RE: Syslog problem
    Posted May 06, 2013 08:33 AM
    I suggest that you configure the syslog level to warning on all the categories since the warning level gives you better information overall  (too much or too little but in between ).
    See if that works.
    What version are you running ?
