Too low speed that I expected on IAP-277 Point-to-Point Bridging(Mesh Portal/Point)
Dear All,
I have configured Point-to-Point Briding on IAP-277(Mesh Portal/Point) like below topology.
I got this kind of result of Mesh link estabished.
HT-Detials is VHT-80Mhz-3ss. According to 802.11ac specfication I am expecting around 1.3Gbps speed.
But, Real Speed of IAP-277 Point-to-Point Bridging I have gotten is around 100~150Mbps maximum.
Test environment is as below.
-Indoor Lab testing environment.
-The distance between IAP-277 is 10m long.
-Traffic generator is "iperf3.exe".
Question #1: Is it normal speed of IAP-277 ,  Missconfiguration or H/W problem?
Question #2: if not a H/W Problem, any suggestion or configuration setting to optimize and speed up to 1.3Gbps on IAP-277?
Question #3: the speed difference between AP#1->AP#2(Around 100Mbps) and AP#1 <- AP#2(Around 10Mbps) is too high I think. How do I make both speed as almost equal? Give me some configuration command or suggestions for this.
FYI, I attached some of tech support files.
Moon-Kee Bahk.
Re: Too low speed that I expected on IAP-277 Point-to-Point Bridging(Mesh Portal/Point)
You have three issues that I can see:
min-tx-power 24  <------Min and max should be 12  TX power of 24 can cause distortion and cause throughput issues
max-tx-power 127
rf dot11a-radio-profile
spectrum-monitor  <-------Remove this, because it can lower throughput
If you do an iperf, you need to include -w512k to make the windows size 512k
You will not get 1.3ghz because wireless is half duplex....  You would be lucky if you get half of that.
Dear Colin Joseph,
Thanks about your wonderful comment for us.
I got around 315Mbps max speed after applying with your comment. but still hungry regarding speed.
Even our testing lab is not located in electromagnetic shielded room, but I expect around speed half of 1.3Gbps speed.  we cannot see any channel interference, also.
Moon-Kee Bahk.
Regular Contributor I
Distance 10m ? Make that a greater distance or lower tx power.
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Moon-Kee Bahk wrote:
Dear Colin Joseph,
Moon-Kee Bahk.
Mr. zero is correct.
Mimo relies on multiple paths to get better performance.  If the APs are close too each other, they have line of sight and there is only a single path.  Make the distance greater between them and put an object between the two APs.
Next, try the following parameters for iperf:
iperf -c <ip address of server> -w 1M -t 300 -I 5
At that distance, even a power of zero is likely still driving the radios pretty high and will cut down on throughput. Also, in case you aren't, you should be pushing 6-8 TCP streams across that link as well, not just a single stream.
Jerrod Howard
As there are no clients to be served by the IAPs, what is the maximum p2p link speed in this case in theory?
Is there any option to utilize both radios to enhance the throughput?
We have seen max speeds of around 700Mbps in the most ideal cases when testing PtP, but real world speeds would be 500-600Mbps in clean channels with VHT80 (which again if there's any interference anywhere in the 80Mhz spectrum, that speed will drop). 274_5712_PtP.png
Jerrod Howard
