Interface :wifi0
ARM History
Time of Change Old Channel New Channel Old Power New Power Reason
1970-01-01 02:01:09 36+ 36+ Max 18 P-
Interface :wifi1
ARM History
1970-01-01 02:35:59 1 11 18 18 M
1970-01-01 02:01:09 1 1 Max 18 P-
I: Interference, R: Radar detection, N: Noise exceeded, Q: Bad Channel Quality E : Error threshold exceeded, INV: Invalid Channel, G: Rogue AP Containment, M: Em pty Channel, P+: Increase Power, P-: Decrease Power, 40INT: 40MHZ intol detected on 2.4G, NO40INT: 40MHz intol cleared on 2.4G, OFF: Turn off Radio, ON: Turn on Radio
Kitchen# show log system
Jan 1 02:00:34 syslog: <341005> <ERRS> |AP Kitchen: | open core directory failed
Jan 1 02:00:34 syslog: <341005> <ERRS> |AP Kitchen: | terminal access is enabled but sshd is n ot running, starting
Jan 1 02:00:38 nanny[1712]: <303022> <WARN> |AP Kitchen: | Reboot Reason: AP rebooted Thu Jan 1 00:00:09 PST 1970; Restore AP ENV.
Jan 1 02:00:48 cli[1760]: <341317> <WARN> |AP Kitchen@192.168.1.241 cli| Regulatory table file init at version 1.0_49142, build Mar 19,2015.
Jan 1 02:00:49 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| Extended ssid enabled
Jan 1 02:00:49 cli[1760]: <341207> <WARN> |AP Kitchen@192.168.1.241 cli| AP support up to 16 S SID.
Jan 1 02:00:49 cli[1760]: <341172> <WARN> |AP Kitchen@192.168.1.241 cli| Find enet0 name eth0.
Jan 1 02:00:49 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| cli starting, clearin g any dpimgr
Jan 1 02:00:50 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| cli_choose_eth_uplink :eth current uplink set to DHCP
Jan 1 02:00:50 cli[1760]: <341169> <WARN> |AP Kitchen@192.168.1.241 cli| Add uplink Ethernet 0 .
Jan 1 02:00:50 cli[1760]: <341167> <WARN> |AP Kitchen@192.168.1.241 cli| Uplink eth0 type Ethe rnet, state INIT->LOAD.
Jan 1 02:00:50 cli[1760]: <341169> <WARN> |AP Kitchen@192.168.1.241 cli| Add uplink Wifi-sta 6 .
Jan 1 02:00:50 cli[1760]: <341169> <WARN> |AP Kitchen@192.168.1.241 cli| Add uplink 3G/4G 7.
Jan 1 02:00:50 cli[1760]: <341167> <WARN> |AP Kitchen@192.168.1.241 cli| Uplink type Dummy, s tate INIT->LOAD.
Jan 1 02:00:50 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| receive sapd hello fo r process recovery
Jan 1 02:00:51 cli[1760]: <341174> <WARN> |AP Kitchen@192.168.1.241 cli| No current uplink, pi ck the highest one - Ethernet eth0.
Jan 1 02:00:51 cli[1760]: <341263> <WARN> |AP Kitchen@192.168.1.241 cli| enable uplink eth0.
Jan 1 02:00:51 cli[1760]: <341167> <WARN> |AP Kitchen@192.168.1.241 cli| Uplink eth0 type Ethe rnet, state LOAD->PROBE.
Jan 1 02:00:51 cli[1760]: <341265> <WARN> |AP Kitchen@192.168.1.241 cli| enable ethernet uplin k eth0.
Jan 1 02:00:51 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| the ethernet uplink i nuse in first time, get ip address.
Jan 1 02:00:51 cli[1760]: <341167> <WARN> |AP Kitchen@192.168.1.241 cli| Uplink eth0 type Ethe rnet, state PROBE->UP.
Jan 1 02:00:51 cli[1760]: <341185> <WARN> |AP Kitchen@192.168.1.241 cli| Retrieving ip address from br0, ip 192.168.1.241, mask 255.255.255.0.
Jan 1 02:00:51 cli[1760]: <341274> <WARN> |AP Kitchen@192.168.1.241 cli| Update election ip fr om br0, election ip 192.168.1.241/255.255.255.0.
Jan 1 02:00:51 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| build_my_ip_address: old ip and new ip same; skipping
Jan 1 02:00:51 cli[1760]: <341006> <CRIT> |AP Kitchen@192.168.1.241 cli| Sending uplink_up msg to sapd
Jan 1 02:00:51 cli[1760]: <341006> <CRIT> |AP Kitchen@192.168.1.241 cli| trap uplink info.
Jan 1 02:00:51 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| last uplink is null, it's the first uplink, ignore this trap.
Jan 1 02:00:51 cli[1760]: <341173> <WARN> |AP Kitchen@192.168.1.241 cli| Current uplink set to Ethernet, state UP.
Jan 1 02:00:51 cli[1760]: <341135> <WARN> |AP Kitchen@192.168.1.241 cli| Master Changed - new 192.168.1.240 old 0.0.0.0 current swarm state 0.
Jan 1 02:00:52 cli[1760]: <341135> <WARN> |AP Kitchen@192.168.1.241 cli| Master Changed - new 192.168.1.240 old 0.0.0.0 current swarm state 1.
Jan 1 02:00:55 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| Swarm State Change fr om Found to Image_ok
Jan 1 02:01:00 nanny[1712]: <303073> <ERRS> |AP Kitchen@192.168.1.241 nanny| Process /aruba/bi n/radiusd-term [pid 1880] died: got signal SIGTERM
Jan 1 02:01:00 nanny[1712]: <303079> <ERRS> |AP Kitchen@192.168.1.241 nanny| Restarted process /aruba/bin/radiusd-term, new pid 2061
Jan 1 02:01:00 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| restart dhcp helper a nd dnsmasq!!!
Jan 1 02:01:01 cli[1760]: <341307> <WARN> |AP Kitchen@192.168.1.241 cli| recv_config_init: rec eive config from master 192.168.1.240, using url 0, auto save disable 0.
Jan 1 02:01:02 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| Extended ssid enabled
Jan 1 02:01:02 cli[1760]: <341207> <WARN> |AP Kitchen@192.168.1.241 cli| AP support up to 16 S SID.
Jan 1 02:01:02 cli[1760]: <341172> <WARN> |AP Kitchen@192.168.1.241 cli| Find enet0 name eth0.
Jan 1 02:01:02 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| cli starting, clearin g any dpimgr
Jan 1 02:01:03 cli[1760]: <341205> <WARN> |AP Kitchen@192.168.1.241 cli| Applying enet config : port eth1.
Jan 1 02:01:04 cli[1760]: <341205> <WARN> |AP Kitchen@192.168.1.241 cli| Applying enet config : port eth2.
Jan 1 02:01:05 cli[1760]: <341205> <WARN> |AP Kitchen@192.168.1.241 cli| Applying enet config : port eth3.
Jan 1 02:44:32 cli[1760]: <341271> <ERRS> |AP Kitchen@192.168.1.241 cli| ethernet uplink eth0 link down.
Jan 1 02:44:32 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| stopping DHCP on bond 0
Jan 1 02:44:32 cli[1760]: <341185> <WARN> |AP Kitchen@192.168.1.241 cli| Retrieving ip address from uplink, ip 192.168.1.241, mask 255.255.255.0.
Jan 1 02:44:32 cli[1760]: <341274> <WARN> |AP Kitchen@192.168.1.241 cli| Update election ip fr om br0, election ip 192.168.1.241/255.255.255.0.
Jan 1 02:44:32 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| build_my_ip_address: old ip and new ip same; skipping
Jan 1 02:44:32 cli[1760]: <341167> <WARN> |AP Kitchen@192.168.1.241 cli| Uplink eth0 type Ethe rnet, state UP->DOWN.
Jan 1 02:44:32 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| uplink failure on sla ve
Jan 1 02:44:32 cli[1760]: <341263> <WARN> |AP Kitchen@192.168.1.241 cli| enable uplink .
Jan 1 02:44:32 cli[1760]: <341167> <WARN> |AP Kitchen@192.168.1.241 cli| Uplink type Dummy, s tate LOAD->PROBE.
Jan 1 02:44:32 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| enable dummy uplink
Jan 1 02:44:32 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| disable SSID[TP-LINK_ 2.4GHz_967EFD
Jan 1 02:44:33 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| uplink failure on sla ve
Jan 1 02:44:35 cli[1760]: <341167> <WARN> |AP Kitchen@192.168.1.241 cli| Uplink type Dummy, s tate PROBE->UP.
Jan 1 02:44:35 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| uplink failure on sla ve
Jan 1 02:44:45 cli[1760]: <341272> <ERRS> |AP Kitchen@192.168.1.241 cli| ethernet uplink eth0 link up.
Jan 1 02:44:45 cli[1760]: <341167> <WARN> |AP Kitchen@192.168.1.241 cli| Uplink eth0 type Ethe rnet, state DOWN->UP.
Jan 1 02:44:45 cli[1760]: <341166> <WARN> |AP Kitchen@192.168.1.241 cli| Get interface br0 ip: 0.0.0.0/0.0.0.0.
Jan 1 02:44:45 cli[1760]: <341005> <ERRS> |AP Kitchen@192.168.1.241 cli| ethernet up without i p address, setup ip now
Jan 1 02:44:45 cli[1760]: <341181> <WARN> |AP Kitchen@192.168.1.241 cli| Uplink eth0, setup ip for uplink - Ethernet.
Jan 1 02:44:45 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| bring up dhcp client for ethernet uplink
Jan 1 02:44:45 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| /etc/setup_ip_swarm E thernet 1
Jan 1 02:44:45 cli[1760]: <341166> <WARN> |AP Kitchen@192.168.1.241 cli| Get interface br0 ip: 192.168.1.241/255.255.255.0.
Jan 1 02:44:45 cli[1760]: <341185> <WARN> |AP Kitchen@192.168.1.241 cli| Retrieving ip address from br0, ip 192.168.1.241, mask 255.255.255.0.
Jan 1 02:44:45 cli[1760]: <341274> <WARN> |AP Kitchen@192.168.1.241 cli| Update election ip fr om br0, election ip 192.168.1.241/255.255.255.0.
Jan 1 02:44:45 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| build_my_ip_address: old ip and new ip same; skipping
Jan 1 02:44:45 cli[1760]: <341006> <CRIT> |AP Kitchen@192.168.1.241 cli| Sending uplink_up msg to sapd
Jan 1 02:44:45 cli[1760]: <341006> <CRIT> |AP Kitchen@192.168.1.241 cli| trap uplink info.
264> <WARN> |AP Kitchen@192.168.1.241 cli| disable uplink .
Jan 1 02:44:45 cli[1760]: <341167> <WARN> |AP Kitchen@192.168.1.241 cli| Uplink type Dummy, s tate UP->DOWN.
Jan 1 02:44:45 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| disable dummy uplink
Jan 1 02:44:45 cli[1760]: <341004> <WARN> |AP Kitchen@192.168.1.241 cli| enable SSID[TP-LINK_2 .4GHz_967EFD
Kitchen# Kitchen# show log system
