Turning down the transmit power on a IAP275
Hi
We have a cluster of IAP205 in a warehouse and 1 x IAP275 for external wireless access.  I would like to turn down the transmit power of the IAP275 as I believe that it is causing wireless handhelds not to roam correctly.  Current using ARM for the power and signals.  Transmit power in the RF profile restricted to between 12dbi and 15dbi as requested by the handheld manufacturer.
Should I just change the settings in ARM for the individual external access point?  I would ideally like to leave the channel choice up-to ARM but manually restrict the power.
Any assistance gratefully received.
