[Tutorial] Building a VPN from a IAP Cluster to a Wireless Contoller
Hello! in this guide ill teach you how to build a VPN tunnel from your IAP Cluster to the wireless controller
Prerequisites: you need a controller on 6.2 .x version!
There are many modes in which you can build this tunnel but expecifically ill teach you how to build a vpn tunnel to the controller on local network Nated by VC
First let see the config on the IAP
Lets go to VPN option on the IAP
You select IPSEC and on the primary host you put the ip address of the controller which should have a port mapping to your controller with a public ip address with the ipsec ports
then click next
Here you add the networks that you want to reach on your  central site, the default gateway would be the public ip address of the controller.
Click finish
Now go to more again and go to DHCP Server
add a new scope with a ramdom vlan, with a network of your preference.  When you fniish click ok
Now lets go to the SSID creation
Create a new network
There you put network assigned, and you put static and put the random vlan you created before, then you can set whatever you need on the other paramehters and click finish.
We are done on the Instant APs
Now on the controller side
You need to add the mac address of the IAP on your controller like this
(Aruba3400) #local-userdb-ap add mac-address 00:11:22:33:44:55 ap-group test
Or you can add it on the gui on the remote APS whitelist
After that you need to create a vpn pool like this
(Aruba3400) # ip local pool "rapngpool" <startip> <endip>
You can do it also by gui on vpn services.
Take in mind that the range you put in there should be a routable range that exist on the controller. for example  in my case for this demostration i used this vpn range
Becauase i got a interface vlan like this
Which as you see that range is routable in my controller(not sure if you guys get my point?)
Then you need to create a IAP role like this
(Aruba3400) (config) #ip access-list session iaprole
(Aruba3400) (config-sess-iaprole)#any host <radius-server-ip> any src-nat (Aruba3400) (config-sess-iaprole)#any any any permit
(Aruba3400) (config-sess-iaprole)#!
(Aruba3400) (config) #user-role iaprole
(Aruba3400) (config-role) #session-acl iaprole
(Aruba3400) (config) #aaa authentication vpn default-iap
(Aruba3400) (VPN Authentication Profile "default-iap") #server-group default
(Aruba3400) (VPN Authentication Profile "default-iap") #default-role iaprole
(Aruba3400) (VPN Authentication Profile "default-iap") #!
Now if you got many address pools like me for many different things like this
then you will need to select the correct one on the iap role like this
You go to the iaprole on access control and look for the l2tp pool and select the correct one, in my case is vpn liek this
After this you are done!
you can check if the vpn is up by doing show iap table
And you should see your vpn up in there...
Anyways i hope this help you guys
Cheers
Carlos
[Mod note: edited title for readability]
Alternetworks Corp
Re: [Tutorial]Building a VPN from a IAP Cluster to a Wireless Contoller
This is a great overview.  I would also add that folks understand all the DHCP (L2,L3,Local) depending on your scenario.  The one in the post above is basically a local DHCP server and ALL client traffic is NAT'ed out of the virtual controller.  It really depends on the scenario.
For L2 extension like our traditional RAPs, it would be L2,Centralized
For a L3 extension which should be used for remote teleworkers or branch offices, please review and consider L3,Distributed.  It is what I recommend almost 100% of the time.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
thanks Seth
Ill try making a tutorial forhte L3 deployment another day
Cheers
Carlos
Alternetworks Corp
Can I make a suggestion that you post this to the Aruba Solution Exchange??
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Great guide NightShade1.
Take a look at the solution, https://ase.arubanetworks.com/solution/name/iap_vpn/, on Solution Exchange.  This solution helps configure IAP VPN to Mobility Controller either over distributed L2 or distributed L3.  I just added a link on the solution to this thread as an additional reference point for other users.
Excellent link thank you very much!
Cheers
Carlos
Alternetworks Corp
Did you just made that tutorial? hahaha it just got like 10 mins there :)
Alternetworks Corp
It's actually been around since August but it shows when the solution was last modified, which was just recently to add a link to this thread.
Re: [Tutorial] Building a VPN from a IAP Cluster to a Wireless Contoller
Carlos,
I followed your turtorial, and I'm still having some issues.
I do have a unique setup that may differ from normal production environments.
Using ArubaOS 6.3.1.2
Instant 6.3.1.2-4.0.0.3
I'm trying to make this function in a test environment without the availability of public IP facing the internet.  So all IP interfaces are private.  This could add some issue itself.
I do have a router/firewall in between the IAP and the controller, on the recommendation that I could have a route to the controller in addition to the VPN tunnel.  This could cause two paths which could interfere my testing.
First issue is getting the VPN connected.  I do not see the the vpn in the "show iap table"
However, the VPN shows "up" in the Instant UI.
I also see the IAP in the AOS Monitor tab > Clients > (two entries, one for the inner and one for the outer IP)
Behavior seen is the VPN status on the IAP goes up and down.  The inner IP address changes each time it does this.
I can't access any of my controller VLANs that I have set up in the route section for the VPN on the IAP.
Any suggestions?
Colin
Hello Collin King
If you cannnot see the tunnel up on show iap table then the tunnel is not up...
Can you show me some kind of network diagram? to see what you are doing in your lab?
Cheers
Carlos
Alternetworks Corp
