Occasional Contributor I
Two IAP-205 with different settings: which settings will be overwritten?
I'm just starting out with Aruba Wi-Fi and got a question regarding automatic provisioning of Access Points.
I have two IAP-205, I have connected them and set up all the settings that I need, on Instant config panel.
Then I powered on just one of them, AP2, and changed the settings.
If now I connect both of them to the network and power on, which settings will be used for the Wi-Fi? Old ones (from AP1) or new ones (from AP2)?
Thanks!
Re: Two IAP-205 with different settings: which settings will be overwritten?
If AP2 stays up after you made that change then when AP1 comes up the new changes will be pushed to the AP1 from AP2
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Alright, thank you!
And I guess if I turn them on at the same time, the random configuration will be kept..
At that point it will depend on each IAP came up faster and that will determine which one becomes the master
Thank you
Victor Fabian
Great, got it!
