Upgrade firmware on IAP 225 through virtual controller
When trying to check for firmware updates on the IAP 225 virtual controller I get a "received no response from server" error.  Any idea how I can fix this?
Re: Upgrade firmware on IAP 225 through virtual controller
Do your IAPs have access to the internet?
If not, you can download the software image from support.arubanetworks.com
Tim Cappalli | Aruba Security
Thank you for the reply.  Yes, the AP's do have internet access.  I was able to update them this way once, but now I am trying to check to see if there is another upgrade, but I am getting that error.  I will check out the support site for the software image.
I experienced the same problem. The IAP 225 stated that a firmware upgrade was available. Performed upgrade to 6.3.1.8-4.0.0.8_46401. After reboot I checked to see if there were additional upgrades available and receive the error "received no response from the server"
Connection to the internet works fine.
Trusted Contributor I
salindquist you might get the same message but your situation can be quite different, so my advise is create a new thread provide full info: AP types, network setup, firmware version, other details, ...
i would try it again a while later, might be a internet or auruba server hickup.
i tried it on version 4.1.1.2, 4.0.0.8 and 4.0.0.9 on a IAP-105 (so different AP and different firmware) and it worked fine with all, got either the upgrade message or no new firmware available.
