Hello all!
Trying to upgrade the firmware on a IAP-215 configured in standalone mode and is connected to a PC via ethernet (cat 5e) using the CLI. Is it possible to (as an example), have the firmware I would like to use on a thumb drive and insert it into the PC, and then run the following command:
<upgrade-image ftp://media/usbdisk/ArubaInstant_Centaurus_X.X.X.X-X.X.X.X_XXXXX> ?
Or do I have to host the firmware on an actual FTP/TFTP server or URL?
If I host on an FTP server, how should I be inputing the username and password? IAP-215 is in standalone mode and connected to PC. PC is connected to FTP server (wired or wireless), FTP server has a required username and password.
Example:
<upgrade-image ftp://user@ipAddr/directory1/directory2/X.X.X.X-X.X.X.X_XXXXX> ?
Or is there some other syntax that I should be using?
