Contributor II
Use Wifi as Uplink, and bridge Eth ports
Is it possible to connect an instant/RAP3 using wifi as it's uplink, and then bridge E0,E1,E2 to it?  I want to use the instant/RAP as a wireless bridge with multiple ethernet ports.
Solutions Engineer
CWNA-CWDP-ACMP-ACCP
Re: Use Wifi as Uplink, and bridge Eth ports
Hope this answers your question:
http://www.arubanetworks.com/techdocs/InstantMobile/Advanced/Content/Instant%20User%20Guide%20-%20volumes/Uplink%20Configuration.htm
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Occasional Contributor I
I do evrething but in "Info" "Uplink type: Ethernet" never been change! RAP3 in Instant mode, fw 6.4.0.2. And i no see any attempt to connect RAP to wifi. What can i chek in settings? System > Uplink window in attach.
Valued Contributor I
Are you attempting to connect the RAP-3 to other Aruba IAPs or 3rd party APs?  If connecting to Aruba APs no configuration is necessary and the RAP-3 will join as part of the Mesh network.  WiFi uplink is only used to connect Aruba to 3rd party.
Contributor II
I've tried connecting a RAP3 as a mesh, and connecting it to a third party AP, and it never comes up.  Is Mesh and wifi uplink only available in dual radio iAPs?
Solutions Engineer
CWNA-CWDP-ACMP-ACCP
That's correct, Mesh only works on dual APs
Thank you
Victor Fabian
