Occasional Contributor I
Using Airwave 7.7.9. Try to upgrade AP firmware to 6.3.1.2-4.0.0.3_41784
Using Airwave 7.7.9. Try to upgrade AP firmware to 6.3.1.2-4.0.0.3_41784 using Upload Firmware and Files. I enter all my data and click "add" button. The Airwave logs out and returns to log on screen. This is my first time updating AP firmware using Airwave. Any suggestions? I enclosed a sample image.
Re: Using Airwave 7.7.9. Try to upgrade AP firmware to 6.3.1.2-4.0.0.3_41784
Which IAP platform did you try to upload?  I just successfully did it with the AP134/135 file.
AP-105
