Using Two Certificates SSL in Aruba Instant with Clear Pass Guest
Dear,
I have a problem in my client, because I need to set 2 certificates for work the websites with https and I got just insert 1 certificate.
OBS: I will using for Guest Network with captive portal and other network that using with smart devices.
Is there a limitation in Aruba Instant Cluster?
The ClerPass I got insert 2 certificates in trust, but How to configure in Aruba Instant?
I try insert both in diferent models by WebGui and Cli but, I did not make it.
The IAP are the 315 and the firmware version is 6.5.4.3
Thanks.
Re: Using Two Certificates SSL in Aruba Instant with Clear Pass Guest
Unfortunately this is not possible
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Victor,
In this case just with controller(virtual apliance or Hardware apliance)?
Is there other option for resolve this problem?
Thanks.
Sorry don't understand your question .
What is the business requirement / use case ?
Thank you
Victor Fabian
Sorry. I have an environment that I need to insert two SSL certificates into the Instant IAP 315 cluster to work with the captive portal for the guest network with clearpass, but when I put the two certificates the IAP is only accepting a certificate.
Is there any limitation for adding more than one certificate in Instant IAP?
In the clear pass I normally add the two certificates in trust.
Why do you need two SSL certificates?  Typically you need just a public single SSL certificate that all of your clients would trust.
Colin Joseph
Aruba Customer Engineering
You have reason but this client use two certificates in your wired network and He need using the same certificates.
Is there another way to solve this by Aruba Instant?
What is the desired use case for using two certificates? Please provide full detail about their usage.
Tim Cappalli | Aruba Security
The client uses a certificate issued by the firewall checkpoint only to issue the block for certain sites and it does not want to change the way of use, and the other CA certificate is to do the actual SSL inspection.
When I enter the firewall certificate and then add the CA certificate, the previous one is written in Instant. Can not keep both.
SSL decryption certs would not be installed in the IAP.
