Frequent Contributor II
VLAN tagging issue with IAP
I have some issues with VLAN tagging withIAP-105.
I have a network with 3 VLAN:
VLAN 1:          10.10.0.0/16
VLAN 2:          192.168.2.0/24
VLAN 150:      192.168.150.0/24
VLAN 1 is the management VLAN in the LAN, while VLAN 150 is the management VLAN for the IAP-105 (I define it in the Uplink Management VLAN parameter for the IAP). The network has a Layer3 switch to implement routing beetwen VLANs.
I create two SSIDs, assigning each a Static VLAN ID in the VLAN screen of WLAN definition. The two SSID are:
WiFi-Test1, with VLAN ID 1
WiFi-Test2, with VLAN ID 2
The interface of the switch where I connect the IAP-105 is a trunk with the native VLAN 150 and tagged VLAN 1, 2. The interface in which I connect my laptop is defined Access with VLAN 1.
If a client associates to SSID WiFi-Test1, with an IP in the VLAN 1 network (10.10.0.5), I can't ping it.
If a client associates to SSID WiFi-Test2, with an IP in the VLAN 2 network (192.168.2.5), I can ping it, instead.
I try to substitute VLAN 1 with VLAN 118 (10.118.0.0/16) in the WiFi-Test1 definition, and I create the VLAN 118 in the LAN, defining it tagged in the interface where the IAP is connected: with these changes I can ping a client that is associated to WiFi-Test1, with an IP in the subnet 10.118.0.0/16.
I think that the problem with VLAN 1 tagging should be a bug of the IAP. Is true?
There is anyone else who had a similar problem?
Massimo
Massimo Gallina
Telecommunications engineer - ACMP2013
Contributor II
Re: VLAN tagging issue with IAP
If you connect another machine directly to the switch on VLAN1 can you ping it?
Do you mean in an interface in Access mode with VLAN1? Yes, I can ping it!
Massimo Gallina
I am having a similar problem.
My IAP config:
I have 2 wlan in IAP, and the management interface of IAP is in a native vlan 90 (mngt)
wlan1 - vlan 1
wlan4 - vlan 4
uplink management - trunk - native vlan 90 - allowed all vlans
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 90
no shutdown
wlan ssid-profile WLAN4
index 4
type employee
essid WLAN4
vlan 4
wlan ssid-profile WLAN1
index 1
type employee
essid WLAN1
vlan 1
In my switch (L3) i configured both interfcaces vlan 1 and 4 (with dhcp), and vlan 90 (no dhcp)
(the IAP has an fixed IPaddress).
The uplink to the IAP:
description *** IAP Aruba Test ***
switchport trunk native vlan 90
switchport trunk allowed vlan 1,4,90
switchport mode trunk
no cdp enable
end
The clients connecting to the wlan1 (vlan1) cant´t get an IP. It seems that they are falling into the native vlan 90.
Does the IAP tag the vlan 1? I am missing something?
Thank you all.
gmoutinho
I believe this is a bug in the current IAP firmware I suggest you to contact TAC to confirm it. We ran into similiar issue and got the response that currently IAP does not support using a native vlan other than VLAN 1 on a trunk port of the uplink interface.
Hi, apparently this 'bug' still exists...I've send the below question to support, but I probably should have posted it here.
Here's the question:
I have an issue with a customer who has a 'flat' vlan 1 network.
All clients have a fixed IP in vlan 1.
There was one Instant cluster of about 50 IAP-135 access points, with the following SSID's:
- EMPLOYEES: Radius authentication, client vlan assignment: default vlan, client ip assignment: network assigned (fixed IP's)
- PUBLIC: portal authentication, client ip assignment: Virtual controller assigned (internal dhcp)
- SMARTPHONES: WPA2, client vlan assignment: static vlan 20, client ip assignment: network assigned (external dhcp)
As he wanted different SSID's on different sites I've split the cluster in several small clusters. I've done that by putting the AP's in a seperate native vlan.
This worked fine, for the PUBLIC and SMARTPHONES SSID's, but not for the EMPLOYEES SSID.
As the default (native) vlan wasn't 1 anymore I adjusted the EMPLOYEES SSID to 'client vlan assignment: static vlan 1' (tagged in vlan 1).
But this doesn't seem to work. Somehow it seems impossible to tag VLAN 1 on the SSID / VC.
As I wanted to put the VC controller management IP in VLAN 1 (as all other devices) I've specified this as such in the <system> tab on the VC. After that I completely lost connection with the virtual controller.
The access points of that particular cluster were still accessible via their IP in the native vlan of the cluster.
EX:
cluster 100:
IAP101: 192.168.100.1 / 24
IPA102: 192.168.100.2 / 24
untagged: vlan 100, tagged vlan 1, 20
Virtual Controller: 192.168.100.100 255.255.255.255 -> VC reachable
Virtual Controller: 192.168.1.100 255.255.255.0 vlan 1 ---> after this setting no longer reachable
cluster 200:
IAP101: 192.168.200.1 / 24
IPA102: 192.168.200.2 / 24
untagged: vlan 200, tagged vlan 1, 20
Hi, the VLAN bug still exist. I met it again with IAP-103 with AaubaOS 6.4.0.3-4.1.0.1. It will be fixed in later versions by Aruba??? Massimo
Massimo Gallina
dear,
do the bug steal exist or not . have you contact the Aruba support or not.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Hi
I'm not sure if it's a 'bug' or by design, but is isn't possible to tag vlan 1.
As the customer didn't have a support contract, Aruba support couldn't help me.
Br
Peter
By default IAP consider native vlan as 1 and consider the wireless users traffic from vlan 1 as untagged.
To mitigate this situation we neeed to run the below command in CLI of IAP.
Conf t
enet-vlan <native vlan>
commit apply
This will chnage the default native vlan 1 to the exisitng one.
Sreejith
