Super Contributor II
Viewing AP radio channel mode for Instant / Airwave
Hi All,
when using a mobility controller, you can run the show ap bss table command to identify the channel width and mode (i.e. HT20 / VHT80)
What is the equivalent command for instant? Can this be seen in Airwave?
Scott
Valued Contributor II
Re: Viewing AP radio channel mode for Instant / Airwave
HI Friend,
You can use the same command ( show ap bss-table) to get this information, look at "PHY" column. Airwave do not have any such command.
Please feel free for any further query on this.
Cheers,
Venu Puduchery,
Hi scottdoorey,
as Venu mentions, run 'show ap bss-table' on the CLI for both the controller and IAP.
Venu, you can definitely run this command on Airwave.
Simply Navigate to the IAP-VC that you are interested in and select the drop down "Run command for all APs" and select "AP BSSID Table".
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
thanks all for the responses. Looks like i'll be raising a feature request!
