Virtual Controller become unresponsive in a two cluster deployment of IAP93. What is the reason?
Virtual Controller become unresponsive in a day or two with two cluster deployment environment of IAP93.
We have a student hostel having 20 IAPs, 10 each in two VLANs with same SSID.  Frequently, Airwave reports that either of the two Virtual Controllers are DOWN sometimes both together. The firmware version used  is 6.3.1.2-4.0.0.4_42384.  Pl. help us to solve the issue.
Re: Virtual Controller become unresponsive in a two cluster deployment of IAP93. What is the reason?
Is it possible that you may have an IP conflict ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
We are very sure that it is nothing to do with IP address conflicts.  I fear, it may be an interference issue with one VC's ARM with other VC's ARM, whichever VC ARM wins takes the control and other sleeps infinitely.
Moderator
With two separate VC's in separate vlans they operate completely independant from each other  -- ARM on one VC group is independant of ARM on the other VC group.
You might considder updating the SW as your first step.   Earlier 4.0.0.x seemed to have a lot of random issues similar to this (sorry, I don't have specifics) and they seemed to clear up when upgrading to v. 4.0.0.7.   v.4.1.0.1 is the latest release; HOWEVER, there are a number of limitations imposed on the IAP-9x with 4.1 so be sure the read the Release Notes carefully to see if they apply to your network.
Also, is the outage only being reported in AirWave?   Is the network actually up or down?   What version of AirWave are you running?  8.0.3 is the current release, 8.0.3.1 will be out in the next day or so with fixes for some VisualRF issues, and 8.0.4 will be out in a couple of weeks with IGC for IAP 4.1.
