Voltage for IAP 225
I would like to know the exact voltage required for an IAP-225 to work in normal mode.
I know that it requires POE+ at power . But could you please let me know the voltage value required for the IAP-225 to work in normal mode ?
Re: Voltage for IAP 225
Voltage or Watts?  How are you powering the device?
12V / 15.6W power at the DC port, and ~48V for 802.3af or~54V for 802.3at using ~17.1W. General draw will be approx, as draw will be based on numbers of users, power of the radios, use of USB or second ethernet interface. There is no exact number in each case, as power can fluctuate at stratup and based on outside temperature as well, so you budget for the max draw always.
Jerrod Howard
