WLAN Access-Rule on IAP 135 - What is Maximum Number of Rules Allowed
I have a question about the WLAN Access-Rule feature on a IAP135. I have an IAP135(US) running OS Version 6.3.1.4-4.0.0.5.
I need to add a number of rules for lync ports on the IAP. Basically, I want to prioritize Lync 2013 Ports on the IAP. I have this setup and running well on a Mobility Controller. Trying to apply the same config to the IAP.
I successfully added 9 rules to the WLAN Access-Rule. However, when I try to add another rule to the WLAN Access-Rule, the IAP refused to save the additional rules.
I tried adding rules from the CLI. No change. The IAP will not save the additional rules.
What is the limit on rules that can be configured on the WLAN Access Rule on a IAP 135?
Anthony
Re: WLAN Access-Rule on IAP 135 - What is Maximum Number of Rules Allowed
There is a best practice guide for Lync 2013 and IAPs
http://www.arubanetworks.com/pdf/technology/whitepapers/WP_LyncDeployment.pdf
As far as limit, I am not sure, does the user guide mention anything?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
