WLC Model : Dell PowerConnect W-7210 with Access Points Model: AP-103 Configuration help
Dear All,
I was  trying  to register below Controoller and Access point unfortunitly i cannot able to register the Access point in WLC i have tryied to change IOS as per our community disscussion but  i dont know even i cannot able to change IOS
Kindly please help me for configuring below WLC and Access poing
Somebody can configuration guide of deployment guide very help for me
Plzz share with me i am waiting for the reply
Regards
Muhammed
Re: WLC Model : Dell PowerConnect W-7210 with Access Points Model: AP-103 Configuration help
Is it an AP-103 or a W-AP-103?
Tim Cappalli | Aruba Security
thanks for your reply
AP-103
You need to use Dell branded APs with Dell branded controllers.
Hello Everyone, The AP model is W-AP103, kindly let us know the pre-requisites to register the AP's with the Controller.
Regards
Azmatullah
Regards
Azmatullah
The datasheet on Dell's website here:  http://i.dell.com/sites/doccontent/shared-content/data-sheets/en/Documents/Dell_Networking_103_Series_Access_Points.pdf says AOS 6.4.0.1
Super Contributor I
What version of AOS are you running? If you have valid support with Dell then you should be able to get the new code from them.
ACDX #419 | ACMP |
