Warning: CLI module is running in a degraded state.
Hi Guy's
Has anybody els had this issue, the IAP picks up a IP address but will not join the cluster. I connected to the console and when the AP boots i get a "Warning: CLI module is running in a degraded state." so i took it out the production network and created a seperate network. the unit get's a IP address however if you enter the default admin credentials it comes back saying they are incorrect.
Re: Warning: CLI module is running in a degraded state.
Did you try resetting it on the new network and upgrading it to the code of the existing cluster?
Occasional Contributor I
Hi cjoseph,
I bought the AP-135 for home purpose, and I don't have controller and confiured cluster. When I connect it trough serial console, I saw device was empty and I flash it with software Release_6.4.4.4-4.2.3.2 through tftp. But after reboot CLI is running in degraded mode and Web UI does not allow login. May I do manual provisioning with flashing some default image on second partition, or something else.
Are you putting the IAP-135 on a subnet with dhcp?
Can the IAP get out to the internet so it can contact a time server? (type "show clock" to see if the date is correct).
Yes, and device get address. And has following ports:
PORT     STATE SERVICE
22/tcp   open  ssh
80/tcp   open  http
443/tcp  open  https
4343/tcp open  unicall
8080/tcp open  http-proxy
Trought ssh I can login with admin/admin but shows messgae:
Warning: CLI module is running in a degraded state.  Configuration, write memory, and support command are disabled; please debug with caution.
show tech-support and show tech-support supplemental are the two most useful outputs to collect for any kind of troubleshooting session.
On web I'm not be able to login with admin/admin nor admin/forgetme!
And on web page I saw following status:
Internet: Unreachable
Active uplink: N/A
Celullar Provider: No module installed
Celullar Signal: No module installed
Primary VPN: Not configured
Secondary VPN: Not configured
AirWave: Not configured
I also have serial port to this device. And I can download any file trough tftp.
Thanks a lot in advance,
~Dinko
Can you ping an internet address from the CLI?
you should only use admin/admin  "forgetme" no longer works for instant.
Yes, I can do ping in both direction. From and to the IAP.
6c:f3:7f:c3:07:0e# ping 172.16.0.1
Press 'q' to abort.
PING 172.16.0.1 (172.16.0.1): 56 data bytes
64 bytes from 172.16.0.1: icmp_seq=0 ttl=64 time=1.9 ms
64 bytes from 172.16.0.1: icmp_seq=1 ttl=64 time=0.8 ms
64 bytes from 172.16.0.1: icmp_seq=2 ttl=64 time=0.7 ms
64 bytes from 172.16.0.1: icmp_seq=3 ttl=64 time=0.6 ms
--- 172.16.0.1 ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 0.6/1.0/1.9 ms
The result of CLI command of "show tech-support" is attached to this post.
Sorry for my delay, thanks a lot in advance,
~Dinko
Hi cjoseph,
Do you need more information?
What I need to do to switch off this degraded mode?
I honestly cannot tell from that log.  Let me get someone else to look at it.
It seems like you are trying to join the IAP-135 to an existing cluster?
