Occasional Contributor I
We are experiencing latency and disconnect issues on a couple of IAPs in our cluster.
If I run a show stat command on the IAP I am seeing the following:
Util Level:good
Noise Level:good
Error Level:good
However under the clients section, all clients seem to have either good signal and poor speed, or poor signal and good speed
Clients                Signal  Speed
SIHS-PREP-9    good  poor
Katherine   poor good
SIHS-PREP-10       good    poor
android  poor    good   .
0.0.0.0                   poor    good   0.0.0.0
iPhone                    poor    good
Any ideas what could be causing this, and how to go about remediating the issue?
Many thanks
Richard
Re: We are experiencing latency and disconnect issues on a couple of IAPs in our cluster.
What is is the transmit power of the APs in that cluster?  Too much power (>18) means they can hold on to an AP longer than they should...
Thanks for getting  back to me on this.  Power has been set to Min Transmit 15, Max Transmit 18, as per a recommendation from an Aruba support engineer a while back.
Are you using Broadast Filter ARP on all of your SSIDs?
roadcast Filtering is set to ALL, with Multicasr Transmission Optimization and Dynamic Multicast Optimization both set to off.  These should be no multicast traffic on the network anyway.
Richard
What version of Instant are you running and what model access points?
They are AP-215 running version 6.4.4.8-4.2.4.1_55602
What are the top two devices that are experiencing latency and disconnects?
Are they ever on the 2.4ghz band?
I suspect that they are, however I will need to confirm this.
I can confirm that all the devices are on 2.4Ghz
