When connected to Guest SSID splash page does not display.
we have configured one guest ssid , with network assigned vlan , security is internal acknowledged
able to associate fine with ssid but splash page does not display
when changed mode to virtual controller assigned it works.
Re: When connected to Guest SSID splash page does not display.
Does the client get an ip address when "network assigned" is configured? Does DNS work?
with network assigned it does get IP , then it pops up with internet explorer page for captive portal that does not work is main issues
when changed to virtual controller assigned it does get IP from virtual controller assingned range and captive portal web page does open.
for both captive portal web page address is same.
What is the error message/URL?
page cant be displayed.
And when I changed to virtual controller managed it does use same DNS it does work.
When it is network assigned, is the ip address the client gets routable to the VC address?
No it is not  routed through VC address.
it goes through Client IP -- SVI on switch -- FW INT
