When using AIP115 or AIP105 with virtual controller, roaming is automatically activated?
When using AIP115 or AIP105 with virtual controller, roaming is automatically activated?, or we have to enable 802.11r under the SSID?
I have overlapping needed guaranteed.
would be this configuration needed?
(Instant AP)(config)# wlan ssid-profile <name>
(Instant AP)(SSID Profile <name>)# dot11r
(Instant AP)(config)# end
(Instant AP)# commit apply
Re: When using AIP115 or AIP105 with virtual controller, roaming is automatically activated?
Not all clients support 11r. I would advise against enabling it unless you've tested.
Roaming is a client action/decision. There is nothing that you need to enable.
Tim Cappalli | Aruba Security
ok. I just have to ensure the correct overlapping.
