Frequent Contributor I
When will IAP "show speed-test data" actually show me data?
I set up an iperf server in my datacenter and am trying to test the wired bandwidth available at my remote sites with the fairly new "speed-test" function introduced in Aruba Instant 6.4.3.4-4.2.1.0. I have the following configured and have verified bidrectional traffic with the iperf server.
r08030-iap1 (config) # speed-test
r08030-iap1 (speed-test) # server-ip 10.170.0.50
r08030-iap1 (speed-test) # server-port 5001
r08030-iap1 (speed-test) # sec-to-measure 5
r08030-iap1 (speed-test) # include-reverse
r08030-iap1 (speed-test) # protocol tcp
r08030-iap1 (speed-test) # bandwidth 10
r08030-iap1 (speed-test) # time-interval 60
r08030-iap1 (speed-test) # end
r08030-iap1# commit apply
However, when I try to show the data from the speed test I get this:
r08030-iap1# show speed-test data
Speed Test results :
Speed Test Error :Test data not available
I've seen the test run several times in the iperf server but still can't show any data on the IAP. What am I missing?
Re: When will IAP "show speed-test data" actually show me data?
What version of Iperf are you running at your datacenter?
What model IAP is it?
^C[root@stlnetapp-prd3 ~]# iperf -v
iperf version 2.0.5 (08 Jul 2010) pthreads
r08030-iap1# sh ver
ArubaOS (MODEL: 215), Version 6.4.4.4-4.2.3.0
Website: http://www.arubanetworks.com
Copyright (c) 2002-2016, Aruba Networks, an HP company.
Compiled on 2016-03-17 at 00:57:19 PDT (build 54225) by p4build
FIPS Mode :disabled
AP uptime is 1 hour 55 minutes 31 seconds
Reboot Time and Cause: AP rebooted Wed Apr 13 13:44:33 UTC 2016; Image Upgrade Successful
Here's how I'm launching iperf:
[root@stlnetapp-prd3 ~]# iperf -s
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
[ 4] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 65115
[ 5] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 65116
[ 6] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 65117
[ 7] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 65118
[ 8] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 65119
[ 9] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 58975
It must be iperf3
ThisIsToCheckNaming# show speed data
Time of Execution :Wed, 13 Apr 2016 21:45:24 GMT
Server IP :192.168.1.25
Local IP :192.168.1.246
Local Port :50314
Remote Port :5201
MAC :f0:5c:19:ca:20:74
System Name :ThisIsToCheckNaming
Protocol :UDP
Duration :20
Upstream Bytes :2609000
Upstream Bandwitdh(bps) :1043590
upstream Datagrams sent :2609
upstream Jitter(millisec) :1.0645
Upstream Lost packets :0
