Where can i enable/disable spectrum load balancing in virtual controller?
Are there any place in virtual controller to enable/disable the spectrum load balancig? Maybe this mode dosen't exist in the new virtual controller, because it is override by clientmatch, is it right?
Thanks for all,
Re: Where can i enable/disable spectrum load balancing in virtual controller?
IAP# conf t
We now support CLI commit model, please type "commit apply" for configuration to take effect.
IAP (config) # arm
IAP (ARM) # no spectrum-load-balancing
Thank you
Victor Fabian
Lead Mobility Architect
Moderator
Spectrum Load Balancing can also be enabled / disabled in the WebUI.  Click on RF in the upper right-corner then "Show Advanced Options".
You are correct, however, in that with ClientMatch enabled SLB will be ignored.
