Why would mesh be disabled on a an IAP-115 running 6.3 code%3F
Hello All,
I have one IAP-224, running as a VC that i want to use as a mesh portal and one IAP-115 which i am trying to setup as a mesh point. If i plug the IAP-115 into the L2 network, it becomes part of the cluster no problem. As soon as i disconnect the ethernet and turn it back on, it elects itself master and finally reboots after about 2 or 3 minutes.
Both my IAP-224 and IAP-115 tell me MESH not supported in the mode
I had also tried turning on bridging for ethernet 0 but all that really does is bypass teh uplink check and not much else.
Anyone have any ideas as to what might be wrong?
Re: Why would mesh be disabled on a an IAP-115 running 6.3 code%3F
Mesh is not currently supported on 11ac access points.
Tim Cappalli | Aruba Security
Valued Contributor I
As cappalli mentioned Mesh is not supported on the IAP-22x till later this year.
Also, for the IAP-115 to join a Mesh you need to make sure "Extended SSID" is disabled.   This is found under System ->Advanced Options.
