Wi-Fi client segregation per SSID
We have IAP 255 devices.
Is there an option for Wi-Fi client segregation, per SSID? That is to stop Wi-Fi clients from being able to communicate with each other on a given WLAN segment.
Re: Wi-Fi client segregation per SSID
(config)# deny-inter-user-bridging
GUI
System > General > Advanced Options > Deny inter-user bridging: enabled
Tim Cappalli | Aruba Security
Is that global or per SSID?
cinfig this gobal but it have in virtual ap in advancement tab for ssid
Sorry, didn’t see that you were asking about per-SSID.
For that, you just enter the command under the SSID profile.
(Instant AP)(config)# wlan ssid-profile <ssid-profile>
(Instant AP) (SSID Profile <ssid-profile>)# deny-inter-user-bridging
(Instant AP) (SSID Profile <ssid-profile>)# end
(Instant AP)# commit apply
This is very useful though I can't figure out how to configure profiles which have spaces in their profile names.. I'm certain it's something simple.
Can someone shed some light on this?
put them in quotes perhaps "name with space" ?
or try tab completion and see if that makes it work.
