Wireless Bridge Reccomendations
I have a client with two buildings each on different sides of a road. I need to setup a wireless bridge setup to extend the LAN to the other building. I need the setup to be basically as fast and reliable as the current 10/100 LAN of the main facility. We currently have CIsco SF300 managed switches in both buildings.
There is currently a wireless bridge setup using some lower end equipment. The connection works ok with 2 people using it but once 3 people connect it gets really slow and basically unusable.
The locations of the two access points would be about 150-200 feet apart. Both would be mounted externally most likely in a weather proof access point enclosure.
Thanks for any help
Valued Contributor I
Re: Wireless Bridge Reccomendations
Take a look at the MST200.  This is part of our AirMesh Outdoor AP family and are ruggedized / fully sealed so no enclosure is needed.  They are autonomous APs (no controller) and have a built-in, high-gain / directional antenna. They are single-radio 5GHz and are perfect for a P2P bridge link.
Super Contributor II
I tested the MST200 bridge link at around 250 metres and the results were pretty poor - when we raised this with Aruba we were told that the link is designed for Km distances and that was the reason for the low link speed.
ed
Contributor I
I have used the MST200 at a site where the buildings are about 330 Meters apart.  I configured the connection to use a 20Mhz channel width and receive a connection at 130Mb/s.  I could have used the 40Mhz width but using the 20Mhz allowed for me to configure using a channel with less interferance.  The far end does not have much of a load and is supporting VOIP connections to the far building as well as their internet connection.
250 meters should have worked just fine with the MST200. The predicted throughput should be: HT20 TCP down 47 – 95Mbps, -59dB         HT40: TCP down 82-164Mbps, -59dB.
On really short links you may need to decrease the Tx power but at 250 meters that should not be necessary.
Could there have been: lot's of interference, problems with clear LoS, or impingement in Fresnel Zone?
We tested this out in the middle of nowhere so there would have been no interference and clear LoS, however for Fresnel zone impingement - I didn't make any calculations for this. The APs were fitted about four metres up on tripods - but I cant believe this would account for speeds of around 30Mbps.
What RSSI value are you getting on the mesh link from both sides?
ed
Contributor I
Here is what I am getting on the MST200 that I have in production. Distance of APs is around 330 Meters
Link quality: 82%, Data rate: 130M, RSSI: 48, SNR: 48,
Input rate: 36.49 Kbps, Output rate: 13.16 Kbps.
Thank you! Matt, could you share your results as well?
This is all I have kept from those tests -
bin/iperf.exe -s -P 0 -i 1 -p 5001 -f k
Server listening on TCP port 5001
TCP window size: 8.00 KByte (default)
20MHZ test 1 -
[236] local 192.168.11.3 port 5001 connected with 192.168.11.4 port 49382
[ ID] Interval       Transfer     Bandwidth
[236]  0.0- 1.0 sec  1784 KBytes  14618 Kbits/sec
[236]  1.0- 2.0 sec  1880 KBytes  15404 Kbits/sec
[236]  2.0- 3.0 sec  1880 KBytes  15404 Kbits/sec
[236]  3.0- 4.0 sec  1904 KBytes  15594 Kbits/sec
[236]  4.0- 5.0 sec  1928 KBytes  15795 Kbits/sec
[236]  5.0- 6.0 sec  1920 KBytes  15726 Kbits/sec
[236]  6.0- 7.0 sec  1969 KBytes  16126 Kbits/sec
[236]  7.0- 8.0 sec  1984 KBytes  16249 Kbits/sec
[236]  8.0- 9.0 sec  1928 KBytes  15793 Kbits/sec
[236]  9.0-10.0 sec  1904 KBytes  15600 Kbits/sec
[236]  0.0-10.1 sec  19208 KBytes  15633 Kbits/sec
20MHZ test 2 -
[240] local 192.168.11.3 port 5001 connected with 192.168.11.4 port 49383
[240]  0.0- 1.0 sec  1729 KBytes  14163 Kbits/sec
[240]  1.0- 2.0 sec  1880 KBytes  15398 Kbits/sec
[240]  2.0- 3.0 sec  1904 KBytes  15601 Kbits/sec
[240]  3.0- 4.0 sec  1871 KBytes  15329 Kbits/sec
[240]  4.0- 5.0 sec  1896 KBytes  15532 Kbits/sec
[240]  5.0- 6.0 sec  1896 KBytes  15532 Kbits/sec
[240]  6.0- 7.0 sec  1912 KBytes  15662 Kbits/sec
[240]  7.0- 8.0 sec  1937 KBytes  15864 Kbits/sec
[240]  8.0- 9.0 sec  1936 KBytes  15863 Kbits/sec
[240]  9.0-10.0 sec  1935 KBytes  15855 Kbits/sec
[240]  0.0-10.3 sec  19408 KBytes  15506 Kbits/sec
20MHZ test 3 -
[228] local 192.168.11.3 port 5001 connected with 192.168.11.4 port 49384
[228]  0.0- 1.0 sec  1784 KBytes  14615 Kbits/sec
[228]  1.0- 2.0 sec  1913 KBytes  15671 Kbits/sec
[228]  2.0- 3.0 sec  1903 KBytes  15591 Kbits/sec
[228]  3.0- 4.0 sec  1920 KBytes  15731 Kbits/sec
[228]  4.0- 5.0 sec  1888 KBytes  15470 Kbits/sec
[228]  5.0- 6.0 sec  1920 KBytes  15729 Kbits/sec
[228]  6.0- 7.0 sec  1887 KBytes  15460 Kbits/sec
[228]  7.0- 8.0 sec  1897 KBytes  15541 Kbits/sec
[228]  8.0- 9.0 sec  1935 KBytes  15854 Kbits/sec
[228]  9.0-10.0 sec  1887 KBytes  15462 Kbits/sec
[228]  0.0-10.2 sec  19424 KBytes  15529 Kbits/sec
40MHz test 1 -
[252] local 192.168.11.3 port 5001 connected with 192.168.11.4 port 49399
[252]  0.0- 1.0 sec  3041 KBytes  24911 Kbits/sec
[252]  1.0- 2.0 sec  3495 KBytes  28632 Kbits/sec
[252]  2.0- 3.0 sec  3385 KBytes  27728 Kbits/sec
[252]  3.0- 4.0 sec  3431 KBytes  28110 Kbits/sec
[252]  4.0- 5.0 sec  3305 KBytes  27071 Kbits/sec
[252]  5.0- 6.0 sec  3528 KBytes  28901 Kbits/sec
[252]  6.0- 7.0 sec  3544 KBytes  29036 Kbits/sec
[252]  7.0- 8.0 sec  3488 KBytes  28572 Kbits/sec
[252]  8.0- 9.0 sec  3407 KBytes  27914 Kbits/sec
[252]  9.0-10.0 sec  3497 KBytes  28646 Kbits/sec
[252]  0.0-10.1 sec  34352 KBytes  27963 Kbits/sec
40MHz test 2 -
[240] local 192.168.11.3 port 5001 connected with 192.168.11.4 port 49400
[240]  0.0- 1.0 sec  2792 KBytes  22873 Kbits/sec
[240]  1.0- 2.0 sec  3232 KBytes  26480 Kbits/sec
[240]  2.0- 3.0 sec  3360 KBytes  27528 Kbits/sec
[240]  3.0- 4.0 sec  3183 KBytes  26077 Kbits/sec
[240]  4.0- 5.0 sec  3169 KBytes  25957 Kbits/sec
[240]  5.0- 6.0 sec  3272 KBytes  26801 Kbits/sec
[240]  6.0- 7.0 sec  3273 KBytes  26811 Kbits/sec
[240]  7.0- 8.0 sec  3487 KBytes  28567 Kbits/sec
[240]  8.0- 9.0 sec  3400 KBytes  27851 Kbits/sec
[240]  9.0-10.0 sec  3497 KBytes  28644 Kbits/sec
[240]  0.0-10.1 sec  33176 KBytes  26793 Kbits/sec
40MHz test 3 -
[148] local 192.168.11.3 port 5001 connected with 192.168.11.4 port 49401
[148]  0.0- 1.0 sec  3281 KBytes  26878 Kbits/sec
[148]  1.0- 2.0 sec  3656 KBytes  29947 Kbits/sec
[148]  2.0- 3.0 sec  3585 KBytes  29368 Kbits/sec
[148]  3.0- 4.0 sec  3534 KBytes  28955 Kbits/sec
[148]  4.0- 5.0 sec  3672 KBytes  30082 Kbits/sec
[148]  5.0- 6.0 sec  3704 KBytes  30346 Kbits/sec
[148]  6.0- 7.0 sec  3664 KBytes  30012 Kbits/sec
[148]  7.0- 8.0 sec  3675 KBytes  30102 Kbits/sec
[148]  8.0- 9.0 sec  3646 KBytes  29865 Kbits/sec
[148]  9.0-10.0 sec  3624 KBytes  29690 Kbits/sec
[148]  0.0-10.1 sec  36424 KBytes  29553 Kbits/sec
Done.
