Wireless Connection issues while roaming with Lenovo Laptops
We haev bought new Lenovo Laptops recently and current facing the issue with couple of laptops. When Laptops moved from one location to other (Roaming), laptops is not able to connect back to wirless network. Sometime it is frequently disconnecting for approx. 10 minutes or so then get stable connection. Again with Stable connection, there are lots of packet drops if I try to ping the gateway from laptop. Also the similar issue when doing the hibernate.
Aruba AP USed : IAP-204/IAP205
Version : 6.4.2.0-4.1.1.0_46028
Details of the Lenovo Laptop is as below.
Model : Lenovo Thinkpad X1 Carbon
OS : Windows 7 Enterprise
Wireless LAN Card : Intel® Dual Band Wireless-AC 7260
Driver Version : 17.16.0.4
Is anybody help what could be issue?
Regular Contributor II
Re: Wireless Connection issues while roaming with Lenovo Laptops
That is a common issue with intel 7260 driver try to update the driver or tweak the adapter settings
Please upgrade your ap to 4.1.1.7 if you can. Many issues are fixed in 4.1.1.7. Please let me know if you have trouble getting 4.1.1.7
Colin Joseph
Aruba Customer Engineering
MVP
Hello!
Do you have Client Match active on the Cluster? We have a similar scenario with a customer also using Lenovo laptops, but in this case it's not limited to only that brand. We worked with TAC and ended up turning off Client Match while waiting for a 4.2 release to solve our scenario..
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
The Client match is not enable in our Infrastructer.
Niren
