Occasional Contributor I
a critical Problem with MY IAP-93
Dear All
i have a big problem with My IAP-93 i have bought six IAP93 i have configured first 1 with My SSID name and password also i put the other five 1 by 1 and seems to take configuration from the first one(VC) i have configured And every thing works just fine for 2 days
then i realized that the VC IP i logon into has been changed automatically and the connected IAPs is 5 not 6 i go to see the VC it was Red at Wireless led then i restarted It 2 times nothing happen still Down I go to the other VC which working i have configured the IP of VC to from the Old VC to The New one which i already on its web page  then the first VC comes back online then every thing works Fine for another day after that the new VC goes Down a new IAP takes the role Of VC then the Hole wireless system is down with big delay i have realized that all APs are in the same Channel I have ro configure it manually after i didi this after 2 days all my settings was overrided and all back to same channel while they already Have the MANUAL!!!!!! Settings so What really is happening over here
firmware version is 5.0.3.0-1.1.0.1(even if the firmware is old is this normal?!!!!!)
Thanks in advance
Re: a critical Problem with MY IAP-93
Did you try to upgrade the firmware?
no sir i did not I have an image file of this version 6.1.3.1-3.0.0.2_34479
i was afraid to do so thing go worst But i will upgrade today after working hours so if i upgrade the VC do i have to upgrade all of the remaining IAPs or they just upgraded automaticlly from the upgraded VC?
All the IAPs will upgrade their code when the VC upgrades.
this is the controller after upgrading the Firmware to 6.1.3.1 as u can see i have marked 3 IAPs they are in the same place to fulfill about 80 users also all IAPs channles and Power are automticlly controled by the VC but as u can see two of them have the same channel which will make interferance and brining down the wireless network
Note:-
at info the VC name is "Aruba master" but the "IAP  of the VC IP "name is aruba apple is this a problem in configuration also here is the configuration:-
version 6.1.3.0-3.0.0
virtual-controller-country EG
virtual-controller-key 2fddcaab0122e1e4f953d81c68e231fa8549ea8c61acf552e9
name "Aruba master"
virtual-controller-ip 172.27.2.57
ntp-server ntp.org
clock timezone Cairo 02 00
rf-band all
allow-new-aps
allowed-ap d8:c7:c8:cf:c8:44
allowed-ap d8:c7:c8:cf:c7:9c
allowed-ap d8:c7:c8:cf:c7:76
allowed-ap d8:c7:c8:cf:c7:bf
allowed-ap d8:c7:c8:cf:c7:b3
allowed-ap d8:c7:c8:cf:c8:09
arm
wide-bands 5ghz
min-tx-power 18
max-tx-power 127
band-steering-mode prefer-5ghz
air-time-fairness-mode fair-access
client-aware
scanning
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
mgmt-user admin 2c440ebe90a2e32a4bb8b4e1888657ce0ab143774c960e19
wlan ssid-profile "Almasry Alyoum"
index 0
type employee
essid "Almasry Alyoum"
wpa-passphrase ce1c46c7ec2bc530ce85305ee5c50acd5a8b3ce6d675ab22
opmode wpa-psk-tkip,wpa2-psk-aes
max-authentication-failures 0
rf-band all
captive-portal disable
dtim-period 1
inactivity-timeout 1000
broadcast-filter none
blacklist
enet-vlan guest
wlan access-rule default_dev_rule
index 0
rule any any match any any any permit
wlan access-rule "Almasry Alyoum"
index 1
wlan access-rule test
index 2
wlan external-captive-portal
server localhost
port 80
url "/"
auth-text "Authenticated"
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
wireless-containment none
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 1
shutdown
access-rule-name default_dev_rule
speed auto
duplex full
no poe
enet1-port-profile default_wired_port_profile
enet2-port-profile default_wired_port_profile
uplink
preemption
enforce none
You only have 3 channels (1,6,11) to choose from, so all your access points need to be on 1,6 or 11.  The access point chooses the one with the least interference.  If two end up on the same channel, that is not necessarily a bad thing.  Those channels may have the least interference.
Your virtual controller ip address is 172.27.2.57.  You should log into that address to manage your VC cluster.
Thank you for your reply
but i thought because they are in the same open place with the same Channel will make interference anyway i will let it as it is now
and test the network today and will give you what actually happened thanks again :manhappy:
Looks like every thing works fine last two days after upgrade also the Controller automatically figured the interference and changed the Corresponding channels automatically i hope this last forever thx for all feed backs
