ap-105 on virtal controller with wrong ip address
I have 24 ap-105 with ArubaOS 6.2.1.0-3.4.0.3. In Virtual Controller 23 Access points have the right ip address, 1 have a wrong ip address! IP address is manually configured to 192.168.199.242 and it ping and ssh to the right ip address.
IP adress 192.168.199.130 is incorrect and do not respond to any ip port.
Sending result of "show aps scanning"
NameIP Address2.4 Reqs2.4 Voice Rejs2.4 Video Rejs5.0 Reqs5.0 Voice Rejs5.0 Video Rejs
Rgg_2192.168.199.2351449021030144943101
Rgg_3192.168.199.2479249140919300
Oncologia192.168.199.224924100921600
Palestra192.168.199.237932500930400
Farmacia192.168.199.239928600932800
Punto_Prelievi192.168.199.229935300935300
Allergologia192.168.199.227932000933800
Cup192.168.199.234929000933400
Medicina_1192.168.199.221935700935300
Chirurgia192.168.199.2339224500928400
Medicina_2192.168.199.222925900925700
Riab_spec_1192.168.199.241932800932930
Medicina_3192.168.199.223930800935600
Sala_operatoria_2192.168.199.230931500929100
Riab_spec_4192.168.199.23293121309353660
Sala_Operatoria_1192.168.199.240932800932900
Rgg_1192.168.199.2369236909247690
Riab_spec_2192.168.199.226929000927300
Palestrina192.168.199.238936100931800
Riab_spec_3192.168.199.2319281270092549050
Endoscopia192.168.199.225893800886500
Acc_ricoveri192.168.199.244931600935300
Poliambulatori192.168.199.243927600923300
Riab_spec_5192.168.199.1309530095200
There is a command to rescan APs from virtual controller?
I tried to convert the AP to standalone and rejoin to virtual control, but it was useless.
Re: ap-105 on virtal controller with wrong ip address
Did you try the reset proceudre?  http://community.arubanetworks.com/t5/Controller-less-WLANs/Where-is-the-reset-button-on-the-IAP-and-how-do-I-reset-the-IAP/ta-p/180980
No, because the APs are very difficult to reach so I was looking for a remote solution.
