block client-to-client and allow external to initiate sessions
Im trying to block client-to-client traffic and at the same time allow some external networks to initiate sessions with wirless clients. Ive tried to add the following rules, which deny clients-to-clients traffic but also block external networks to contact clients.
allow any on server 10.95.0.1(gateway)
deny any to network 10.95.0.0/24(wireless subnet)
allow any to all destination
Whats the best practice in this situation?
Re: block client-to-client and allow external to initiate sessions
http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/GeneralConfTasks/Adv_conf_tasks/ConfigureInterUserBridging.htm
Deny inter user bridging is enabled.
Currently im running acl in the switches that the IAPs are connected to to allow/deny traffic between clients that are on different IAPs. I would like to skip this and manage everything from the IAP controller.
If that is the case, use what you mentioned in your first post.  You would configure a role for your users, then rules within it:  http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/Roles_and_policies/ConfACLRule.htm
The rules below that you mentioned in your first post would work:
 You do not have to allow traffic to your default gateway.  Hopefully you have no server resources like DNS or anything on 10.95.0.0/24
The problem is that the external network 192.168.10.0/24 needs to initiate sessions with the wireless clients. And the deny any to network 10.95.0.0/24 rule will block this, right?
Unfortunately, I think that is the case..
