Frequent Contributor II
can I have IAP-105 and IAP-205 and IAP-225 in the same cluster?
Can i have IAP-105 and IAP-205 and IAP-225 to be in the same cluster ?
Re: can I have IAP-105 and IAP-205 and IAP-225 in the same cluster?
Yes ,just need to make sure that all the IAPs are running the same version of code
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Regular Contributor II
Infact the VC upgrades or downgrades new members automaticaly.
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
