captive portal for non guest SSID
Can we use  internal  captive  portal of IAP for  non guest SSID's
Re: captive portal for non guest SSID
Yes, you can.
Contributor II
Can I used an internal and external captive portal at the same time.  If so can I use it as a SSID for non=guest and the external for Guest users?
