change controller ip on controller and airwave
Hi all,
our 7200 series controller (master/standby) currently has 2 vrrp ips on 2 different subnets/vlans (both routed)
airwave (monitor only) is connected to the, lets call it "old" vrrp-ip
our goal is to remove the old vrrp ip together with the vlan, without adding a "new" device to airwave.
airwave ip and "old" controller ip are in the same subnet (vlan)
what i already did:
added second vrrp-ip on new vlan
changed the default gateway to the new vrrp-ip network.
changed the aruba-master dns-entry to the new vrrp-ip (all APs are using new VRRP already)
added the new vrrp-ip to our radius-server for client-auth
my questions are:
how to remove the vlan without having to add the device to airwave again?
we have a visualRF with 120 aps on that controller, i dont want to place them again....
is there anything else i should be aware of, before removing the vlan with the main ips?
regards
Dtwo
Re: change controller ip on controller and airwave
- change the ip address of the device in Airwave, and it should poll the new ip address without problems
Hey Joseph,
thanks for the reply, but i cannot find the option to change the ip in airwave.
the device is in "monitor only + firmwareupdates" mode in airwave.
regards
Dtwo
In Airwave go to AP / Devices, select the folder that  your controller is in. Click on your controller then select the manage tab. You can then change the IP:
2016-06-28 11_49_26-77.44.121.11 - Remote Desktop Connection Manager v2.2.jpg
Cheers
James
thanks all.
works like a charm!
