Occasional Contributor I
Re: connect via sah key to IAP
Is ther a solution for IAP?
#AirheadsMobile
Okay thank you
#AirheadsMobile
Okay thank you
#AirheadsMobile
Is ther an other way to send an "disconnect user" command to the IAP with out password authentication?
#AirheadsMobile
The only other ways require password authentication:
1.  XML-API http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-add-delete-clients-using-XML-API-for-IAP/ta-p/292469
2.  An expect script...
Okay thank you very much
#AirheadsMobile
