connecting a distant IAP to my Virtual Controller ?
hy,
i'm trying to connect to my Virtual Controller, a distant IAP which is at a remote office (different network range), connected by IPSEC VPN.
i can see the IAP mac in red in my management interface, but i failed adding it.
it is possible to do that ?
Aruba
Re: connecting a distant IAP to my Virtual Controller ?
They need to be on the same network segment.
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
