Occasional Contributor I
converting iap to cap
i am trying to convert iap-93 to cap but it fails i see it cannot connect to port 21 in error logs any help appreciated.
show vpn status
profile name:default
current using tunnel                            :unselected tunnel
ipsec is preempt status                         :disable
ipsec is fast failover status                   :disable
ipsec hold on period                            :600
ipsec tunnel monitor frequency (seconds/packet) :5
ipsec tunnel monitor timeout by lost packet cnt :2
ipsec     primary tunnel crypto type            :Cert
ipsec     primary tunnel peer address           :N/A
ipsec     primary tunnel peer tunnel ip         :N/A
ipsec     primary tunnel ap tunnel ip           :N/A
ipsec     primary tunnel current sm status      :Init
ipsec     primary tunnel tunnel status          :Down
ipsec     primary tunnel tunnel retry times     :0
ipsec     primary tunnel tunnel uptime          :0
ipsec      backup tunnel crypto type            :Cert
ipsec      backup tunnel peer address           :N/A
ipsec      backup tunnel peer tunnel ip         :N/A
ipsec      backup tunnel ap tunnel ip           :N/A
ipsec      backup tunnel current sm status      :Init
ipsec      backup tunnel tunnel status          :Down
ipsec      backup tunnel tunnel retry times     :0
ipsec      backup tunnel tunnel uptime          :0
end of show vpn status
show upgrade info
Image Upgrade Progress
Mac                IP Address   AP Class  Status       Image Info                     Error Detail
24:de:c6:c0:7a:a4  10.26.2.249  Orion     downloading  ac-ftp://10.26.2.5/mips32.ari  Retrieve image fail
Auto reboot           :enable
Use external URL      :enable
end of show upgrade info
show log upgrade
----------Download log start----------
Executing '/aruba/bin/download_image_swarm ac-ftp://10.26.2.5/mips32.ari --no-proxy X-Ap-Info:BU0072836,24:de:c6:c0:7a:a4,AP-93'
fetching ('/usr/sbin/wget -T 120 -t 3 --no-proxy --header=X-Ap-Info:BU0072836,24:de:c6:c0:7a:a4,AP-93 -a /tmp/download_url_log ftp://sap:x@10.26.2.5/mips32.ari')
--00:04:03--  ftp://sap:*password*@10.26.2.5/mips32.ari
           => `mips32.ari'
Connecting to 10.26.2.5:21... failed: Connection refused.
Error: failed to retrieve image
cleaning up
done
----------Download log end------------
Download status: Retrieve image fail
----------Upgrade log start----------
upgrade log not available
----------Upgrade log end------------
Upgrade status: upgrade status not available
end of show log upgrade
show log rapper
Rapper info not available
end of show log rapper
Re: converting iap to cap
Looks like your controller doesn't have the required code. What version of AOS is running on your controller?
Tim
Tim Cappalli | Aruba Security
Valued Contributor II
HI,
In order to convert an IAP to RAP, Controller should have minimum 6.1 Image version and also there is a minimum 4.1 IAP version,
Please check whether you are justifying the above along with other RAP related settings and RAP whitelist DB.
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
I am running aos 6.3.1.6 on the controller
and on the IAP-93 aos is greater than the one on the controller
Rijo
Both the AOS of the controller and IAP is above 6.1
also control plane security is disabled on the controller
controller
Model:Aruba7210
Version:6.3.1.6
IAP93 version is
Version:
6.3.1.8-4.0.0.8_46401
Any help highly appreciated,
Thanks Rijo
Please upgrade the IAP version to 4.1 or higher.
Cheers,
Venu Puduchery,
The AOS is above 4.1 as mentioned earlier,
Rijo
HI, in your prev post you said, it is on 6.3.1.8-4.0.0.8,
AP93 version is
Version:
Upgrade the IAP to 6.3.1.8-4.1.x.x or above
Cheers,
Venu Puduchery,
These IAP's were previously converted to CAP and was working perfectly.
We then copied the config from an old controller to the 7200
it was reset recently and since then i am not able to convert it back to CAP.
How could this relate to the firmware.
Also there are other IAP-93 with same firmware still on the network working as CAP.
HI,
For converting IAP to CAP or IAP to RAP we have min image version criteria. I will share the doc If I find any.
Cheers,
Venu Puduchery,
