Contributor II
disable low data rates IAp
where do I disable low data rates on instant?
Re: disable low data rates IAp
On the SSID, under advanced
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor II
Is there a recommended setting for this? I know Aruba recommends disabling low data rates on the controller, dont recall the setting though.
You don't have to disable rates at all. We only recommend it when you want to improve performance when there is more density than usual. Assuming you have no 802.11b clients in your environment, you can start by disabling everything under 12. You can measure how you are doing based on the RF utilization before and after you made the change. Again, this is 100% optional and not mandatory.
