Occasional Contributor I
does iap-93 access points support spectrum monitor mode%0D%0A
I am trying to experiment with spectrum mode on an IAP-93-US access point. The option is there to choose. I select it, reboot the access point. I then log back into the web ui but I don't see the "Spectrum" link. I am sort of doubtful that this feature is really in the IAP-93 because I saw in documentation that support for this feature begins with IAP-104 and up. Can someone shed some light on this for me?
Thank you,
Adil
Re: does iap-93 access points support spectrum monitor mode
Spectrum is not supported on the IAP-93.
Tim Cappalli | Aruba Security
