Trusted Contributor I
fixed IP info for IAP
probably totally overlooking this but how can i set fixed IP info for an IAP? I can set the virtual controller ip itself and then connect fine, but how to set gateway / mask / ...?
Aruba
Re: fixed IP info for IAP
The virtual controller IP you speak of is used to have a static IP to manage a multi-Instant  AP network.   It is assigned to the IAP that becomes a Virtual Controller in the event the initial one fails.  There is no way to set the mask or gateway for this setting.
To give the IAP itself a static IP, click the IAP you want to change under the Access Points tab.  Click Edit. You can change the name and IP (mask,gw,dns,etc.).
AMFX | ACCX | ACDX | ACMX
thanks, as expected i totally overlooked it, will give it a try when i boot it again.
