how do I configure IAP 215 with virtual controller with 3 vlans
All I have 3 IAP 215 and 1 IAP 205 I'm looking for a configuration guide and/or wisdom on how to configure the IAP 215 with a mgmt vlan 25 and vlan 35 for wireless with DHCP comming from an network switch.
also the IAP 205 with have mgmt vlan 25 with vlan 45.  do you folks have any knowledge or white paper you could share?
Re: how do I configure IAP 215 with virtual controller with 3 vlans
Thakn you for this very helpful link.
